  • 309 Vote(s) - 2.69 Average
liftmaster CB11 hold gate open problem
hello, istalled this system about 4 years ago for a customer, works perfectly since...problem now is, customer wants to hold open the gates, to put bins out, or for guests arriving...this panel unbelievably does not seam to have this option...having spoken to easygates, i was informed that if a switch was connected between 17 and 20 and left closed, the gates would remain open, this is NOT the case, they still close at the end of the timing cycle...it was then suggested for 1 leaf opening, use carpark mode...i altered the dips for this, pressed switch, gates open and stay open....fantastic! except that all further impulces are ignored...so you cant close them!....this is rather annoying and embarrasing, as the customer must be wondering if i know what i am doing!...there must be a solution to this, if you know what its is, please help me!
the system as installed is CB11,RF module,chamberlin photo cells, impulse from video entry on 17 and 20 [via relay] output for drive lights [via relay] the addition is a single channel self contained remote and receiver with latching or momentary relays, purely to be used for manual open/close of gates [non timed] thanks[/size]
liftmaster CB11 hold gate open problem - by sparkey - 30-01-2013, 08:35 PM
RE: liftmaster CB11 hold gate open problem - by brucekwilles - 13-05-2013, 08:17 AM
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 1,711 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,147 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Sun affecting gate opener ForestRon 2 12,457 02-09-2024, 03:54 PM
Last Post: ForestRon
  My swing gates are stuck at 50% open jctrotting 1 4,558 11-04-2024, 08:11 AM
  Liftmaster LA400 Defender 6 23,517 03-08-2023, 12:26 PM
Last Post: Torantrieb
  CB11 Multiple Keypad support Pigsfoot 1 5,634 12-08-2022, 08:14 AM
  odd liftmaster scs300-24 scopie88 3 22,355 13-04-2022, 10:20 AM
  Problem with delay time CB11 milan 2 15,417 04-10-2021, 01:44 AM
Last Post: DesmondVog
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 24,198 22-02-2021, 08:48 PM
Last Post: russ
