  • 300 Vote(s) - 2.82 Average
gates keep tripping
If it happens whenever you try to operate them then the problem might be either with the automation control board, the motor itself or the flashing light, if one exists (these are the common cases). A *qualified technician* can run a simple test to see which of the two causes the problem by disconnecting the motor and flashing light and testing the operation of the control board. This is mentioned in order to suggest that diagnosing the cause is usually easy and NOT to encourage you to do any testing/repair yourself.
However, if the problem is independent of the operation of the automation (ie at the moment you connect the power to the motor the breaker is tripped) then the list of potential problem areas would include the cable that provides power to the automation.
In any case, a qualified electrician or gate automation installer should be able to help you.
gates keep tripping - by nick - 24-11-2012, 11:17 AM
RE: gates keep tripping - by acsys - 26-11-2012, 08:03 AM
RE: gates keep tripping - by Mark - 11-12-2012, 12:27 PM
  BFT swing gates pushing closed instead opening Marc 0 3,499 08-09-2024, 06:33 PM
Last Post: Marc
  Problems with Came gates ElFinnFlor 1 8,906 07-08-2024, 09:00 AM
Last Post: Skibuddy
  Life electric gates control box Gates head 1 8,015 12-10-2023, 01:09 PM
  Roger Technology Edge1 automatic gates JOKER 1 8,627 08-08-2023, 02:11 PM
  Hydraulic Or Electro Mechanical For Timber Solid Body Gates? geddyMortgage 2 13,561 14-09-2021, 09:35 AM
  House WG2 Gates will not close mousetarget 4 18,500 29-03-2021, 01:40 PM
Last Post: mousetarget
  Keeping gates open Toby 1 14,939 28-02-2018, 12:46 PM
Last Post: Tim
  Reset controll from operating two gates to one andrew.rennie@health.wa.gov.au 1 14,939 17-10-2016, 10:13 AM
  Best choice 4 opposite swinging gates? apeg 1 13,743 28-04-2016, 06:31 PM
Last Post: Russ Dalley
  Moovo gates kev1234567 0 9,786 26-03-2016, 05:28 PM
Last Post: kev1234567
