  • 342 Vote(s) - 2.9 Average
LM 800a lamp problem
(20-07-2012, 04:51 PM)jgj Wrote: I have a Liftmaster 800A, about 5 years old, and the lamp in the unit now stays on permanently. Pressing the lamp button on the wall switch causes the normal click from within the unit as though a relay is trying to operate, but the lamp stays on although very slightly dimmer. I've removed the bulb as a temporary solution, but I'd like to repair it if it's not too expensive. Is it a fault on the control board, or is there a separate relay that has stuck closed?
Regards, John
You will need to contact Liftmaster as we dont know what is causing that fault. Please get in touch with Liftmaster and they should be able to identify the fault and give you a part number as to what you need to order.
Liftmaster UK Helpline : 01935 823900
LM 800a lamp problem - by jgj - 20-07-2012, 04:51 PM
RE: LM 800a lamp problem - by Mark - 23-07-2012, 09:41 AM
  Chamberlain Liftmaster Professional Problem Upandover 1 18,659 27-04-2020, 08:37 AM
Last Post: Upandover
  Problem with Sly300 CB22 not closing Del 1 22,619 21-03-2014, 06:09 PM
Last Post: Del
  1000A remote problem macallan 5 46,559 24-04-2013, 08:30 AM
Last Post: binsonwilles
