  • 314 Vote(s) - 2.73 Average
Proteco Q60A n2 error code
(10-05-2012, 10:36 AM)Proteco_UK Wrote: Hi
Thank you for your posting.
Indeed thank you for running a test i would have suggested (fooling board to think there is only one motor attached and running both independently from it) – however, if you swapped both motors round to begin with, would you still see N2? If this was the case, without a doubt I would feel there is an issue developed with terminals 16/17/18 and would look towards:
• The condition of the spade contacts on that terminal grouping
• The condition of the reverse side of the control board on the off chance something has run across the copper tracking
• The level of torque on that terminal grouping output (parameter F2)
Kind Regards
Gate Motors Technical Support
Kind Regards
now appears possible that there is an element of damp not visible but hidden between the PCB and underside of components on the Rt. 230V half of the board ,
Any more suggestions ?
Yours sincerely
Horace
Thank you for your response
I have examined all three possibilities suggested but with no success
It
Proteco Q60A n2 error code - by Horace - 04-05-2012, 05:28 PM
RE: Proteco Q60A n2 error code - by Proteco_UK - 10-05-2012, 10:36 AM
RE: Proteco Q60A n2 error code - by Horace - 11-05-2012, 09:00 AM
RE: Proteco Q60A n2 error code - by Proteco_UK - 22-05-2012, 10:51 AM
  Thalia P - BAR error devsolo 3 18,350 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,263 17-01-2025, 10:06 AM
  q60a stevea 1 2,692 23-08-2024, 12:14 PM
Last Post: stevea
  TC fault code on Q60ar control board Skydive1710 3 10,135 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,738 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,515 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,833 10-02-2023, 03:19 PM
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,803 03-02-2023, 12:00 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,514 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,735 12-07-2022, 11:48 AM
