  • 383 Vote(s) - 2.76 Average
400 Newton limit on boarded gates
Hi Paul, thanks for your question. If a gate is boarded or not it will still be effected by Wind load, hinge or track fatigue and other elements which increase the amount of force required to move the gate. A gate must not exert more than 400N in crush danger areas of swing or sliding gates, outside of these crush areas the allowed operational force is actually 1400N. The danger areas on gates where the 400N force must be met and tested can be protected using either force limitation (rpm sensor, encoder, clutch), laser light curtain (not photocells) or safety edge's (in some cases a combination of both). Motor Force limitation devices tend to be more difficult to setup and configure due to Wind load as the results may vary from a calm day compared to a very Windy day. Safety edges in combination with less force limitation could be a better option for you as you will be able to run higher forces but by using a smaller active safety edge to protect your gate in the required crush areas. For more infromation on gate crush areas please e-mail asosafety@egduk.com and request a guide to gate safety.
400 Newton limit on boarded gates - by Paul smith - 28-01-2011, 02:50 PM
RE: 400 Newton limit on boarded gates - by easygates - 02-02-2011, 01:20 PM
RE: 400 Newton limit on boarded gates - by Guest - 08-03-2011, 02:16 PM
  Gates not closing Regor23 5 7,879 03-09-2024, 12:51 PM
Last Post: Ivorwindybottom
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 18,036 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,909 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 15,401 14-11-2022, 11:59 AM
  ATS no limit switch finder. A new installation. Aoneautomationnaples 1 4,948 10-10-2022, 10:04 AM
  My Came ZM3E gates won’t open golfnut75 1 11,025 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 15,395 24-06-2022, 08:58 AM
  Came Gates - power cut issues Paddy_SP 2 13,148 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  Came Double Swing Gates opens by itself for some centimeters risp73 0 10,357 19-06-2020, 06:19 PM
Last Post: risp73
  Came gates Ring8180 1 85,577 10-07-2019, 10:39 AM
