  • 497 Vote(s) - 2.84 Average
not opening
#27
Manual, page 13
In the case where an obstacle is found, the LIBRA panel stops the door and activates a reverse manoeuvre; at the same time the display shows the “AMP” message.
Monitoring: During the opening and closing phases, the display shows four digits separated by a dot, for example 35.40. The digits are constantly updated during the manoeuvre, and represent the maximum torque reached by motor 1 (35) and motor 2 (40). These values allow the torque setting to be corrected. If the maximum torque value reached during the manoeuvre gets sensibly close to the value set in the parameter menu, malfunctions may occur in the future following wear or slight door deformation. It is therefore advisable to check the maximum torque reached during some of the manoeuvres carried out in the course of installation, and if necessary set a value about 15-20 percent points higher in the parameter menu.
www.webseb.co.uk
not opening - by nskeates - 26-03-2010, 10:40 AM
RE: not opening - by nskeates - 30-03-2010, 07:38 AM
RE: not opening - by sebabastek - 30-03-2010, 07:03 PM
RE: not opening - by easygates - 31-03-2010, 05:03 PM
RE: not opening - by nskeates - 30-03-2010, 07:49 PM
RE: not opening - by sebabastek - 30-03-2010, 09:10 PM
RE: not opening - by nskeates - 31-03-2010, 07:59 AM
RE: not opening - by sebabastek - 31-03-2010, 07:53 PM
RE: not opening - by nskeates - 31-03-2010, 09:16 PM
RE: not opening - by sebabastek - 31-03-2010, 10:05 PM
RE: not opening - by nskeates - 01-04-2010, 06:48 AM
RE: not opening - by sebabastek - 01-04-2010, 07:35 AM
RE: not opening - by nskeates - 01-04-2010, 07:49 AM
RE: not opening - by sebabastek - 01-04-2010, 08:26 AM
RE: not opening - by nskeates - 01-04-2010, 08:33 AM
RE: not opening - by sebabastek - 01-04-2010, 08:43 AM
RE: not opening - by nskeates - 01-04-2010, 08:23 PM
RE: not opening - by sebabastek - 01-04-2010, 09:36 PM
RE: not opening - by nskeates - 02-04-2010, 08:07 AM
RE: not opening - by sebabastek - 02-04-2010, 09:10 AM
RE: not opening - by nskeates - 02-04-2010, 09:55 AM
RE: not opening - by sebabastek - 02-04-2010, 02:25 PM
RE: not opening - by nskeates - 02-04-2010, 08:10 PM
RE: not opening - by nskeates - 03-04-2010, 07:36 AM
RE: not opening - by sebabastek - 03-04-2010, 12:52 PM
RE: not opening - by nskeates - 06-04-2010, 09:56 PM
RE: not opening - by sebabastek - 06-04-2010, 10:01 PM
RE: not opening - by nskeates - 07-04-2010, 10:07 AM
RE: not opening - by Guest - 29-04-2010, 11:51 AM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,050 14-06-2024, 12:12 PM
  BFT opening problem 8 56,183 08-08-2023, 02:14 PM
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,813 09-01-2023, 10:29 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 20,848 19-08-2022, 09:30 AM
  Strange opening problem Baz1981 4 88,908 15-07-2019, 08:39 AM
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 63,651 23-04-2019, 10:11 AM
  BFT A 40 not opening tojo 0 7,705 06-12-2017, 11:29 PM
Last Post: tojo
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 21,608 23-08-2017, 02:39 PM
Last Post: Access-Control-Ltd
  Strange Gate Opening Issue scottc 5 36,589 09-06-2017, 03:41 PM
  BFT P7 Opening Time / Not Completing Stroke zootreeves 2 16,766 07-01-2016, 08:40 PM
Last Post: zootreeves
