  • 495 Vote(s) - 2.84 Average
not opening
#14
Capacitors are two quite big round tubes with two wires (can be white) – to be honest you can not miss them. They are wired in to the motor outputs.
One sensor can be faulty and if it is giving signal that gate is fully open leaf will not open. You can buy sensors separately (set of two). To test it the best way is to remove motor, remove motor cover and on the top you’ll find small board with terminals for sensors. Put meter across and check if sensors are working properly. There is a little hassle with it but it can be worth doing it. There is also option to rewire system as on Rigel 5 controller you can set opening and closing times instead of opening and closing to reach sensors (if it make sense).
www.webseb.co.uk
not opening - by nskeates - 26-03-2010, 10:40 AM
RE: not opening - by nskeates - 30-03-2010, 07:38 AM
RE: not opening - by sebabastek - 30-03-2010, 07:03 PM
RE: not opening - by easygates - 31-03-2010, 05:03 PM
RE: not opening - by nskeates - 30-03-2010, 07:49 PM
RE: not opening - by sebabastek - 30-03-2010, 09:10 PM
RE: not opening - by nskeates - 31-03-2010, 07:59 AM
RE: not opening - by sebabastek - 31-03-2010, 07:53 PM
RE: not opening - by nskeates - 31-03-2010, 09:16 PM
RE: not opening - by sebabastek - 31-03-2010, 10:05 PM
RE: not opening - by nskeates - 01-04-2010, 06:48 AM
RE: not opening - by sebabastek - 01-04-2010, 07:35 AM
RE: not opening - by nskeates - 01-04-2010, 07:49 AM
RE: not opening - by sebabastek - 01-04-2010, 08:26 AM
RE: not opening - by nskeates - 01-04-2010, 08:33 AM
RE: not opening - by sebabastek - 01-04-2010, 08:43 AM
RE: not opening - by nskeates - 01-04-2010, 08:23 PM
RE: not opening - by sebabastek - 01-04-2010, 09:36 PM
RE: not opening - by nskeates - 02-04-2010, 08:07 AM
RE: not opening - by sebabastek - 02-04-2010, 09:10 AM
RE: not opening - by nskeates - 02-04-2010, 09:55 AM
RE: not opening - by sebabastek - 02-04-2010, 02:25 PM
RE: not opening - by nskeates - 02-04-2010, 08:10 PM
RE: not opening - by nskeates - 03-04-2010, 07:36 AM
RE: not opening - by sebabastek - 03-04-2010, 12:52 PM
RE: not opening - by nskeates - 06-04-2010, 09:56 PM
RE: not opening - by sebabastek - 06-04-2010, 10:01 PM
RE: not opening - by nskeates - 07-04-2010, 10:07 AM
RE: not opening - by Guest - 29-04-2010, 11:51 AM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,145 14-06-2024, 12:12 PM
  BFT opening problem 8 55,393 08-08-2023, 02:14 PM
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,288 09-01-2023, 10:29 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 19,901 19-08-2022, 09:30 AM
  Strange opening problem Baz1981 4 88,283 15-07-2019, 08:39 AM
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 63,173 23-04-2019, 10:11 AM
  BFT A 40 not opening tojo 0 7,520 06-12-2017, 11:29 PM
Last Post: tojo
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 21,201 23-08-2017, 02:39 PM
Last Post: Access-Control-Ltd
  Strange Gate Opening Issue scottc 5 35,951 09-06-2017, 03:41 PM
  BFT P7 Opening Time / Not Completing Stroke zootreeves 2 16,421 07-01-2016, 08:40 PM
Last Post: zootreeves
