  • 298 Vote(s) - 2.7 Average
Can remotes be programmed ?
nig.xl Wrote:In normal use with a Rigel 5 unit set to having the gates open and shut on timer everything is fine. But I wondered is it possible to programme the other button on the remote to open the gates and let them stay open ? e.g. if you have friends arriving but unsure when.
Yes this is possible but you will need a latching 24vac relay.
The coil supply is connected to the 2nd channel which takes its supply form the 24vac terminals on the board on the rigel 5 and the switching contacts on the relay connected to the timer connections
I can supply the connections if you are serious about it
Can remotes be programmed ? - by nig.xl - 28-12-2009, 10:39 PM
RE: Can remotes be programmed ? - by BarkerandGeary - 10-01-2010, 05:55 PM
RE: Can remotes be programmed ? - by 6andrew6 - 06-05-2014, 03:06 PM
RE: Can remotes be programmed ? - by thm - 06-05-2014, 04:21 PM
  Peccinin remotes with BFT control boards lemafla 0 7,469 09-01-2017, 09:49 PM
Last Post: lemafla
