  • 446 Vote(s) - 2.9 Average
chamberlain photocells
You don't have to connect a second set, i always connect my one pair of photocells to open/close 23+ and common 24 - on the CB11 control panel.
But the more photocells you use on your installation the safer it it is!
if all three leds are still flashing red you probably haven't done this procedure correctly
Programming of failsafe photocells model 771E/770E
1.Before the Initial Setup
2.When connecting or removing photocell(s)
- Switch off control board ( disconnect from current)
- Slip jumper on designated pins
- Dipswitch 5 to “ON”
- Connect photocell(s) according illustration
- Reconnect control board, wait short-time
- Pull jumper, wait short-time
Done! (The number of photocells connected are stored)
hope that helps.
chamberlain photocells - by wlehane - 09-07-2009, 10:07 AM
RE: chamberlain photocells - by Sparky - 12-07-2009, 04:19 PM
RE: chamberlain photocells - by Zammo_1 - 28-08-2019, 08:34 PM
RE: chamberlain photocells - by Sav - 02-09-2019, 10:00 AM
  Adding Extra Photocells To CB22 Onoff 0 7,588 06-08-2020, 01:01 AM
Last Post: Onoff
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,132 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
Exclamation lift master SCS300 - photocells Willow 1 13,215 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 9,818 13-07-2016, 11:19 AM
Last Post: Willow
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 15,743 28-03-2012, 12:55 PM
  cb24 photocells devonaloan 1 13,559 28-11-2011, 05:57 PM
  CB24 Kit with a single set of photocells JD1765 1 22,959 07-06-2010, 10:04 AM
  Photocells crafty 1 15,547 12-01-2010, 03:29 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,656 28-06-2009, 10:19 PM
Last Post: Sparky
  LiftMaster CB11 Board Photocells inder 1 15,509 17-03-2009, 03:38 PM
