  • 12 Vote(s) - 2.58 Average
LiftMaster SL400EVK & 722e Failsafe
(19-11-2025, 02:51 PM)Prem Wrote:
(19-11-2025, 01:41 PM)Tucks27 Wrote: Hoping someone can assist.  Have just had a SL400EVK motor fitted and are trying to install that fail safes (772e) that were supplied with it but with little joy.  I have tried connecting one to the of the devices to 24VDC -/+ and the other to IR1 & GND in a number of combinations but with no joy.  The wiring diagram is not clear to me how these should be connected as the booklet supplied with the fail safes don't seem to reference my gate.
Hoping someone has already completed this and can provide some insight!
Many thanks in advance.
Hello,
To begin, connect both positive wires from each photocell sensor to IR1, and both negative wires to GND.
When installing your 772E photocells, it is necessary to perform a motor relearn procedure as follows:
[*]1. Press and hold the "P" button for 5 seconds until the LED displays "AP."
[*]2. Use the positive and negative buttons to scroll through the menu until the display shows "LL."
[*]3. Press and hold the positive and negative buttons simultaneously for 2 seconds, then release. The motors should initiate a position search automatically.
Regards Prem
Many thanks Prem will give it a go!
LiftMaster SL400EVK & 722e Failsafe - by Tucks27 - 19-11-2025, 01:41 PM
RE: LiftMaster SL400EVK & 722e Failsafe - by Prem - 19-11-2025, 02:51 PM
RE: LiftMaster SL400EVK & 722e Failsafe - by Tucks27 - 19-11-2025, 04:35 PM
RE: LiftMaster SL400EVK & 722e Failsafe - by Prem - 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,150 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Liftmaster LA400 Defender 6 23,522 03-08-2023, 12:26 PM
Last Post: Torantrieb
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 24,201 22-02-2021, 08:48 PM
Last Post: russ
  Liftmaster CB1 gates started to open themselves telnet123 4 36,372 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,133 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,474 08-08-2017, 11:23 AM
  Liftmaster SCS300K - stop/go mtuk100 1 18,928 18-04-2017, 09:31 AM
  LiftMaster SUB300M + CB11 fault jonesy1991 0 12,601 25-01-2016, 02:51 PM
Last Post: jonesy1991
