  • 32 Vote(s) - 3 Average
CAME F7000 Gate Openers Issue
[quote pid="18442" dateline="1762155607"]
[quote pid="18424" dateline="1757581471"]
[quote pid="18422" dateline="1756741845"]
Hi Jack,
[/quote]
Thanks for coming back to us on this, just wanted to try something if not tried already to ensure that there is no pre-existing faults on the control panel.
On the CAME ZF1, you have two sets of terminals which are safety inputs on the control board labelled as 2 and C1 and 1 and 2.
If you get some cable, strip either end off the cable and put a link wire between 2 and C1 and another link wire between 1 and 2.
Then try and short across terminals 2 and 7 and see if the gates operate.
[/quote]
[/quote]
Hi Ben,
Sorry this has taken so long to respond. I didn’t see a response had come through. I have done as you said and the gates work. They also work when I press the key fob with the rf module plugged in and the aerial.. When I don’t have the bridges in place the light continues to flash and nothing works. To confirm, there are no other accessories now plugged in and when I plug the keypad in it doesn’t work. I’m assuming that’s because the bridge is in place?
Thanks for getting me this far… the gates at least work on the fob which proves the motor and control panel are working!
Any ideas as to why it only works with those bridges would be helpful.
Thanks,
Jack
CAME F7000 Gate Openers Issue - by Jackolantern - 17-07-2025, 01:54 PM
RE: CAME F7000 Gate Openers Issue - by benbrooks - 11-09-2025, 10:04 AM
RE: CAME F7000 Gate Openers Issue - by Jackolantern - 03-11-2025, 08:46 AM
  CAME ZF4 Controller Issue mduffy89 1 1,936 11-11-2025, 03:14 PM
  CAME sliding gate drops codes after power outage Catch 1 7,808 02-03-2023, 03:18 PM
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 15,544 23-04-2020, 07:11 PM
Last Post: Luke Scott
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,635 02-05-2018, 06:18 PM
  Came sliding gate sticking on opening Jellybean 0 13,006 02-07-2016, 06:53 PM
Last Post: Jellybean
  Came gate opening adjustments TobagoGate 0 31,546 20-12-2012, 02:40 PM
Last Post: TobagoGate
