  • 13 Vote(s) - 2.69 Average
CB124EV with mag lock and Locinox
Hi Ben
Thanks for the reply. I have got it working in the meantime since my original post.
In case this helps anyone else the method I used was to use the yard light contacts on the control board with an external 24v power supply. And setting the light/spy dip switch to light mode.
Looking at the data sheet for the Locinox, it works with either a continuos signal OR a pulsed signal. The lamp contact on the control board closes as soon as the gates start to open, stays closed through the entire gate cycle and then opens after the built in lighting delay (approx 2 mins).
The built in delay between the first wing opening and the second wing opening (the Locinox is on the second wing) is more than enough time for the Locinox to lift.
Andy
CB124EV with mag lock and Locinox - by Boneshed - 29-08-2025, 02:55 PM
RE: CB124EV with mag lock and Locinox - by Boneshed - 11-09-2025, 03:04 PM
  Diagram for mag lock on a CB124EV Defender 8 18,706 12-07-2022, 11:40 AM
  Diagnosis LED on CB124EV jwilco 2 14,746 09-04-2018, 11:25 AM
Last Post: totalebiff
  Mag lock problem richc 1 15,069 27-01-2011, 05:53 PM
  Mag lock wiring diagram for SCS300k elliot330 1 24,315 28-05-2009, 10:38 AM
  Mag lock 1 17,991 27-04-2009, 10:43 AM
  Which lock to use to stop gate moving in the wind marknjo 1 18,837 09-01-2009, 03:20 PM
  SCS 300 / 24 & Viro Lock 1 13,612 05-11-2008, 11:04 AM
