  • 32 Vote(s) - 3 Average
CAME F7000 Gate Openers Issue
(01-09-2025, 04:50 PM)Jackolantern Wrote:
(11-08-2025, 04:20 PM)Jakedugmore Wrote:
Thanks in advance,
Jack
Hi Jack,
(12-08-2025, 04:14 PM)Jakedugmore Wrote:
Really appreciate your response.  I don't have any photocells connected, in fact I have disconnected everything external including the antenna for the remote to check if there was a problem there.  Despite everything being connected, it is still constantly flashing the red light like it is receiving a signal.  When I do connect, even when I link in 7&2 directly, I don't get any relay click and nothing springs into action.  I purchased another PCB just in case and swapped it over, but this one has the same issue and the red light remains constant.
Thanks,
Jack
Hi Jack,
Hi Jake, apologies it took so long to reply.  The control board is the ZF1 and the red led flashing is in the bottom right of the board next to the antenna connection. Note that everything is unplugged and it is still flashing, even when I have changed the board.
Thanks,
Jack
Hi Jack,
Thanks for coming back to us on this, just wanted to try something if not tried already to ensure that there is no pre-existing faults on the control panel.
On the CAME ZF1, you have two sets of terminals which are safety inputs on the control board labelled as 2 and C1 and 1 and 2.
If you get some cable, strip either end off the cable and put a link wire between 2 and C1 and another link wire between 1 and 2.
Then try and short across terminals 2 and 7 and see if the gates operate.
CAME F7000 Gate Openers Issue - by Jackolantern - 17-07-2025, 01:54 PM
RE: CAME F7000 Gate Openers Issue - by benbrooks - 11-09-2025, 10:04 AM
  CAME ZF4 Controller Issue mduffy89 1 1,945 11-11-2025, 03:14 PM
  CAME sliding gate drops codes after power outage Catch 1 7,813 02-03-2023, 03:18 PM
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 15,557 23-04-2020, 07:11 PM
Last Post: Luke Scott
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,642 02-05-2018, 06:18 PM
  Came sliding gate sticking on opening Jellybean 0 13,011 02-07-2016, 06:53 PM
Last Post: Jellybean
  Came gate opening adjustments TobagoGate 0 31,552 20-12-2012, 02:40 PM
Last Post: TobagoGate
