  • 343 Vote(s) - 3.05 Average
Liftmaster 5580 - Overunning Limit Stops
(22-12-2011, 11:06 AM)Mark Wrote: It could be the Limits have been damaged or are jammed and are jumping on the screw adjusters. Your could take to cover off the motor to have a look to see if you can see any physical damage usually if you press screwdrive into the adjuster to hard it can bend the limits.
Other than that i would sujest trying Andrew @ Liftmaster Technical Helpline on 01935 823900 to check see if he has a soloution
Thank you - I will contact Andrew
RE: Liftmaster 5580 - Overunning Limit Stops - by pwrycroft - 22-12-2011, 11:59 AM
  LiftMaster 800 Belt Richard B 2 13,096 20-10-2021, 05:16 PM
Last Post: Richard B
  2 x LiftMaster 800 garage door openers Richard B 2 16,238 07-10-2021, 03:54 PM
  Chamberlain Liftmaster Professional Problem Upandover 1 18,660 27-04-2020, 08:37 AM
Last Post: Upandover
