  • 22 Vote(s) - 3 Average
FAAc xp20d wiring
(04-02-2025, 09:53 AM)benbrooks Wrote:
(04-02-2025, 07:42 AM)Neil Young Wrote: JoeF
(29-01-2025, 10:24 AM)Neil Young Wrote: Hi
I have a pair of faac photocells xp20d that need wiring into the board can anyone help as the storm damage pulled a lot out!! So I am at a loss which wire goes where. Appreciate your help
I have a faac 455 board
Hi Neil,
thanks for the message.
it is difficult to advise as the cables could be joined along the circuit which intern makes connections difficult. you may need an engineer out to meter the cables to ensure they are connected in the correct terminals.
hi Joe many thanks for your reply I have done some digging and searching and I can confirm that
My
tx has a black negative 1
and white positive 2
my rx has
2 green wire
3 yellow wire
4 minus orange wire
5 positive brown wire
looking at the manual I would assume to get the photocells to work I would need to wire
tx 1 to 19
2 to 18
rx
2 to 12
3&4 to 14
5 to 18
But!!! The Manual seems to show on rx a bridge between 2&3??
i checked the advances
programming On the 455d and PH is on Y.
i have taken some photos and tested the wires.
the photocells are powered on now and the light dl1&dl2 are on and if I break the beam with my hand they click of.
But the gates still close and do not stop and reverse!?! Any ideas please
Thanks in advance
Hi Neil,
Thank you for your response.
The photocells would need to be wired as such.
RX Photocell Terminals:
5 - 18 (On Control Panel)
4 - 14 (On Control Panel)
3 and 2 do not have a bridge across, or should not. The diagram you will be looking at is to represent it is a normally closed circuit.
3 - 14 (On Control Panel)
2 - 12/13 (On Control panel, depending on what direction you want the photocells to operate in) CL is for closing direction and OP is for opening direction and they will monitor those manoeuvres.
TX Photocell Terminals:
1 -  4 (On RX Photocell)
2 - 5 (On RX Photocell)
Many thanks just to confirm Ben the
Tx1
1 to 4 on rx or 14 on panel
And
2 on 5 on rx or 18 on panel
I guess if I put the wire in the panel at those points does the same job?
Your help is greatly appreciated
FAAc xp20d wiring - by Neil Young - 29-01-2025, 10:24 AM
RE: FAAc xp20d wiring - by JoeF - 03-02-2025, 10:19 AM
RE: FAAc xp20d wiring - by Neil Young - 04-02-2025, 07:42 AM
RE: FAAc xp20d wiring - by benbrooks - 04-02-2025, 09:53 AM
RE: FAAc xp20d wiring - by Neil Young - 04-02-2025, 12:08 PM
  Beninca TOM4024E wiring Shropshire_Lad 1 2,261 14-07-2025, 01:59 PM
  FAAC gates out of sync TheDock 1 3,479 21-08-2024, 12:21 PM
Last Post: TheDock
  Faac 452 pcb board benner91 2 6,838 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 8,342 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  FAAC E124 fault 05 allan@amtas.com.au 0 3,628 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 9,153 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 4,464 23-06-2023, 03:19 PM
Last Post: Alpin
  BFT gate and Hikvision wiring help Gowrie 0 6,240 26-05-2023, 02:05 AM
Last Post: Gowrie
  FAAC Photocells mmc1977 3 8,421 02-05-2023, 12:37 PM
  Beninca bob motor wiring to board Ranch2 6 13,611 18-11-2022, 09:59 AM
