  • 15 Vote(s) - 2.93 Average
Reclose after photo with exit loop
With a MC824H control panel, 2 sets of blue bus beams and then inside free exit loop, how to get reclose after photo to work without the exit loop triggering the open command again. So automatic closing pause time is set to 60 secs and reclose after photo is active and set to 5 secs. The reclose after photo works fine when exiting the property as the car goes over the loop, the gates open they drive thru the gate and inside and outside photocells then the gate closes 5 seconds later. The problem is when entering the property they open the gate via remote, the gates opens all the way to fully open, they drive thru both sets of beams and then over loop which is a little bit up the road from gate and then the gate doesn’t fast close as it’s been sent another open command and then closes 60 seconds later instead. So tried remapping the open input to apartment block open, as the manual says this is for magnetic detector loop, however it only blocks the second open signal while the gate is opening and not once it is fully open. So is there a way to have the gate open and then ignore any more open commands so reclose after photo will activate?
Reclose after photo with exit loop - by Wilson316 - 20-11-2024, 06:18 PM
  Nice Robus closing after photo Nexur 1 7,662 26-08-2025, 01:47 PM
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 11,399 04-01-2024, 10:06 AM
  Installing Nice photo sensors MC424 polomint 14 66,544 29-03-2021, 06:28 PM
Last Post: pembers
  Nice photo cell Jamie 0 7,347 25-04-2020, 06:22 PM
Last Post: Jamie
