  • 343 Vote(s) - 3.05 Average
Liftmaster 5580 - Overunning Limit Stops
Hi - I have 2 5580s opening a pair of garage doors with canopy arms - both have worked faultlessly for a couple of years but one and now both are giving problems with the opening limit stop. When opened both doors now open fully but continue to run so that they bounce and end up partially closed again. Previously, both had been working perfectly and nothing has been adjusted. I have tried to use the adjuster to correct the problem - tho usually works but I have had no luck this time as the tiniest change makes a huge difference to the doors operation - the adjusters seem very sensitive. Can temperature affect the operation of the adjuster or do I need to replace the adjuster element of the openers. The manual tells me that 1 turn of the adjuster changes the opening by 2 inches - on mine, the slightest twitch makes a massive difference. One 5580 has been doing this for a year or so but has been correctable - the other one started only this week. Is it possible to redatum the limit stops and start again? Hoping for some help - happy to buy some new boards if required - Merry Xmas to all!
Liftmaster 5580 - Overunning Limit Stops - by pwrycroft - 20-12-2011, 12:33 PM
  LiftMaster 800 Belt Richard B 2 13,101 20-10-2021, 05:16 PM
Last Post: Richard B
  2 x LiftMaster 800 garage door openers Richard B 2 16,239 07-10-2021, 03:54 PM
  Chamberlain Liftmaster Professional Problem Upandover 1 18,662 27-04-2020, 08:37 AM
Last Post: Upandover
