  • 27 Vote(s) - 2.63 Average
BFT Deimos BT A600 fault Error 10
(05-03-2024, 04:31 PM)JoeF Wrote:
(04-03-2024, 08:51 PM)GateOpe Wrote:
(25-05-2021, 08:28 PM)Airbus330/300 Wrote:
(24-05-2021, 10:12 AM)JoeF Wrote:
(23-05-2021, 03:28 PM)Airbus330/300 Wrote: I have an error 10 on BFT Deimos BT A 600. Manual states possible motor opening/closing
Contacts are seized.
Can any member advise where new relays for BFT Merak 600 can be purchased.
Relays are   WGR 24vdc.  RD - 124D - H1.      H2023J
Thanks in advance for any assistance,
hope you are well,
unfortunately you cannot purchase this part as a spare and therefore a new control panel will need to be purchased on this occasion
Regards Joe
Hi Joe,
Thank you for the prompt reply.
When testing resistance reading with a multimeter on the motor on BFT Deimos Ultra BT A600,
what should be the resistance reading be?
Many Thanks
Regards Gerry
Hi, i found your message here about BFT Deimos BT A 600 ERROR 10, Can you please tell me was was the fix? since i have exactly the same error now Sad
Error 10 is indicative of the following faults...
ER10
(BT motor)
Motor 1 relay running faulty test
- Motor 1 relay running control circuit failure
- Relay with stuck contacts
- Short circuit mosfet
- Check and remove the causes of possible high absorption of motor 1
- Reparation: replacement of shunt resistance, relay control circuit components, mosfet
It could be any of the following issues which may require replacing the faulty item.
Hi, I already replaced the PCB and unfortunately the error still occur (probably the new PCB also damaged!). Motor was tested with 24v transformer and it was working without any issues
what else i can check?
RE: BFT Deimos BT A600 fault Error 10 - by JoeF - 24-05-2021, 10:12 AM
RE: BFT Deimos BT A600 fault Error 10 - by JoeF - 05-03-2024, 04:31 PM
RE: BFT Deimos BT A600 fault Error 10 - by GateOpe - 06-03-2024, 11:59 AM
  Question BFT Deimos A400 Makaroni 2 4,929 07-05-2025, 05:58 AM
Last Post: OnionBobo
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,393 15-10-2024, 10:37 AM
  bft deimos ultra bt600 error f1 pfloyd 4 8,432 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT deimos smoke from board stanli200188 1 4,270 05-03-2024, 04:17 PM
  thalia error code 3h 35/37/38 detritus 1 6,225 05-01-2023, 11:54 AM
  Lux/Thalia P ersl error Dava12 0 4,929 13-12-2021, 09:35 PM
Last Post: Dava12
  BFT Submotor fault Rockford 0 6,323 18-05-2020, 09:42 PM
Last Post: Rockford
  ERROR 11 TheoLouloudis 0 11,924 10-09-2019, 08:52 PM
Last Post: TheoLouloudis
  BFT Deimos Ultra remote problems shaggy 1 14,849 01-05-2019, 09:43 PM
Last Post: ok.dude
