  • 14 Vote(s) - 3.29 Average
Faac photocell stopped working
(12-01-2024, 09:59 AM)benbrooks Wrote:
(01-01-2024, 01:46 PM)Zeb Gulickx Wrote: Hi
Yesterday my Faac gate would no longer open.
To me, it seems that this is due to a photocell.
Normally the sensors on one side always give 2 blue leds.
When standing in front of the sensor only one light should be on.
Now, there is 1 photocell that always shows only 1 blue led.
The photocell was wet inside. Drying it solved the problem, although it took a while before both the leds where on again.
A couple hours laters, the same problem occurred. Only one led was on while there was no obstruction. It did't rain during these hours.
I can't manage to solve this.
Thank you for your enquiry.
Potentially there could be a short on the photocells' circuit board which could be throwing up this fault; it is hard to say for definite that is one of the assumptions I would make from your detailed enquiry. Could you please inform me of the model number of the photocells, this way I can see if I can get a manual online and assist you further with this issue, however usually with these types of issues when water ingress is present it is usually time to replace the photocells.
Furthermore could you tell me what control panel you are using these photocells with?
Hi Ben
Thank you for your help.
I'm going to replace the photocell. Hopefully, this will solve the issue.
Kind regards
Zeb
Faac photocell stopped working - by Zeb Gulickx - 01-01-2024, 01:46 PM
RE: Faac photocell stopped working - by benbrooks - 12-01-2024, 09:59 AM
RE: Faac photocell stopped working - by Zeb Gulickx - 28-01-2024, 12:56 PM
  FAAc xp20d wiring Neil Young 4 5,856 04-02-2025, 12:08 PM
Last Post: Neil Young
  FAAC gates out of sync TheDock 1 3,325 21-08-2024, 12:21 PM
Last Post: TheDock
  Faac 452 pcb board benner91 2 6,611 09-02-2024, 06:13 PM
  Photocell Problem marcoos_1 4 28,341 04-01-2024, 10:23 AM
  FAAC E124 fault 05 allan@amtas.com.au 0 3,490 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 8,937 03-07-2023, 08:54 AM
  Rigel 5 - second keypad stopped working HarefieldHse 1 4,855 03-07-2023, 08:48 AM
  7pcb452/455 FAAC Alpin 0 4,292 23-06-2023, 03:19 PM
Last Post: Alpin
Exclamation Proteco Q60A stopped working xCO 0 3,379 19-06-2023, 01:03 PM
Last Post: xCO
  FAAC Photocells mmc1977 3 8,132 02-05-2023, 12:37 PM
