  • 15 Vote(s) - 3.13 Average
BFT Rigel 6
(24-08-2023, 01:43 PM)Michael Wrote: Hi Steve,
First you will need to identify which set are causing the issue. i would firstly...
Remove the covers of the photocells (clean them)
Remove one set from the board and link out the terminals for that photocell input. to see whether the fault disappears.
Check for continuity between the cables there could be a break, if you don't have a meter to test this, run fresh cable above ground temporarily.
Easygates Ltd
Thank you for your reply.
In the end i found that what was causing the problem was the pressure sensor on the trailing gate. This communicates with the board via wifi and the sender unit has two batteries inside. When I changed these the gates started working properly again.
Your response was much appreciated as i will keep the info in case i have any further issues with the photocells.
Steve
BFT Rigel 6 - by stevew - 11-08-2023, 04:26 PM
RE: BFT Rigel 6 - by Michael - 24-08-2023, 01:43 PM
RE: BFT Rigel 6 - by stevew - 25-08-2023, 04:09 PM
RE: BFT Rigel 6 - by Michael - 29-08-2023, 08:39 AM
  Rigel 5 , gates won't open Nameloc 4 10,280 04-05-2024, 12:41 PM
Last Post: Alee
  Rigel 5 - second keypad stopped working HarefieldHse 1 5,027 03-07-2023, 08:48 AM
  Strange gate operation Rigel controller Philreghse 0 8,411 10-06-2019, 09:18 AM
Last Post: Philreghse
  Rigel 4 and Clonix not receiving signals apbran 6 32,088 26-03-2017, 05:32 PM
Last Post: apbran
  BFT Rigel LUX FC actuators erratic Berrystead 0 6,952 31-08-2016, 08:19 PM
Last Post: Berrystead
  BFT Rigel 5 graham 2 17,308 20-05-2013, 01:55 PM
Last Post: graham
  BFT Rigel 5 Remote sync Nicks 1 15,025 01-03-2013, 02:15 PM
Last Post: Mark
