  • 238 Vote(s) - 2.89 Average
BFT LUX2B Intermittent failure to open
(14-08-2023, 11:14 AM)john kennedy Wrote:
(22-03-2015, 10:25 PM)brookkr Wrote: One motor occasionally fails to actuate even though the motor can be heard running. Opening the release valve, opening the gate and closing the valve allows it to operate for a few days until it happens again. Have had motor oil refilled / topped up by specialist.
I saw this problem reported before but apparently no solution found. Any clues anyone? Thanks.
I have the exact problem pulling my hair out  Re filled with fluid all ok then one stops  it happens when Sad im not there so have not been able to check voltage yet  and will also try bleeding again also going to swap motors over to see if i can confirm details   iv changed capacitors too   its a BFT  LUX 2B 240v
Thanks for the message,
it is hard to definitely say however, it could be a sign of a failing capacitor if it is the 230v variant of the Lux motor. Have you tried replacing this?
BFT LUX2B Intermittent failure to open - by brookkr - 22-03-2015, 10:25 PM
RE: BFT LUX2B Intermittent failure to open - by JoeF - 24-08-2023, 01:36 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,572 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,713 04-11-2024, 05:59 PM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,911 17-07-2024, 02:24 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 7,296 09-02-2024, 03:12 PM
Last Post: EdwardBab
  BFT sliding gate intermittent operation vozm100 5 9,262 02-10-2023, 09:08 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 13,871 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 10,427 30-05-2023, 01:57 PM
Last Post: mark123499
  BFT controlled gates open but don't close MikeJep 5 28,371 04-01-2022, 09:58 AM
  Phobos N L BT one leaf won’t open BigJC 0 5,117 11-06-2021, 01:33 PM
Last Post: BigJC
