  • 236 Vote(s) - 2.88 Average
BFT LUX2B Intermittent failure to open
(22-03-2015, 10:25 PM)brookkr Wrote: One motor occasionally fails to actuate even though the motor can be heard running. Opening the release valve, opening the gate and closing the valve allows it to operate for a few days until it happens again. Have had motor oil refilled / topped up by specialist.
I saw this problem reported before but apparently no solution found. Any clues anyone? Thanks.
I have the exact problem pulling my hair out  Re filled with fluid all ok then one stops  it happens when Sad im not there so have not been able to check voltage yet  and will also try bleeding again also going to swap motors over to see if i can confirm details   iv changed capacitors too   its a BFT  LUX 2B 240v
BFT LUX2B Intermittent failure to open - by brookkr - 22-03-2015, 10:25 PM
RE: BFT LUX2B Intermittent failure to open - by john kennedy - 14-08-2023, 11:14 AM
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,982 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,369 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,561 04-11-2024, 05:59 PM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,669 17-07-2024, 02:24 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 7,026 09-02-2024, 03:12 PM
Last Post: EdwardBab
  BFT sliding gate intermittent operation vozm100 5 8,870 02-10-2023, 09:08 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 13,351 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 10,042 30-05-2023, 01:57 PM
Last Post: mark123499
  BFT controlled gates open but don't close MikeJep 5 27,916 04-01-2022, 09:58 AM
  Phobos N L BT one leaf won’t open BigJC 0 4,997 11-06-2021, 01:33 PM
Last Post: BigJC
