  • 15 Vote(s) - 2.53 Average
Came BX-74/78
(20-03-2023, 09:10 AM)cjd123x@gmail.com Wrote: Good morning all
My Came BX-74 gate is giving me problems after many years of good service.
The motor suddenlly stopped responding to the remote, all the remotes I have so not a remote problem.
The PCB LED is constantly flashing, I have by-passed the photocells, bridged 2&C1, still the same.
I haev checked all connections and contacts that I can see and so I am looking for some guidance.
Is there anywear I can actuate operation directly on the PCB, I have been working with the covers off but with the lower access door locked.
After looking the wiring over I gather the photocells, 4, are powered from terminals 10 & 11 then continuity returned between 2 & C1, the reason I bridged 2 & C1. Cool
I would appreciate any help.
Chris
Good Morning Chris,
Sometimes the Receivers do fail, so by shorting between terminals 1 and 2. This should give the gate an open command. If the gate doesnt move, its either a block command or constant short on an acccessory terminal preventing it to open. I would recommend taking the board back to basics and either linking out if needed or removing all the accessories. Then if the gate operates from 1 and 2. Re-instate all the accessories one by one. Failing that, it may be a capacitor issue, which will need to be replaced and wired into terminals U and V.
Came BX-74/78 - by cjd123x@gmail.com - 20-03-2023, 09:10 AM
RE: Came BX-74/78 - by SamA - 20-03-2023, 12:14 PM
RE: Came BX-74/78 - by cjd123x@gmail.com - 21-03-2023, 03:15 PM
RE: Came BX-74/78 - by cjd123x@gmail.com - 24-03-2023, 10:53 AM
RE: Came BX-74/78 - by cjd123x@gmail.com - 24-03-2023, 11:30 AM
RE: Came BX-74/78 - by SamA - 24-03-2023, 02:38 PM
RE: Came BX-74/78 - by cjd123x@gmail.com - 24-03-2023, 03:45 PM
RE: Came BX-74/78 - by SamA - 27-03-2023, 08:49 AM
