  • 16 Vote(s) - 3.19 Average
Thalia P - Wireless control board module
(01-03-2023, 11:04 AM)mathewnorris22 Wrote: HI,
Does anybody know if it is possible to replace just the wireless remote module inside a Thalia P control board?
All my remotes have simply stopped working, but everything else functions including the photocells and keypad entry. I have tried reprogramming the remotes and gone through the process as assigning the open button. The control panel seems to detect the fob, when both buttons are pressed, but when you assign the desired button to activate opening the display shows KO rather than OK.
So im wondering if its a problem with the remote module within the control panel itself and if its possible to replace just that particular element?
The receiver on the Thalia P is integrated into the control board.
If that has failed. You may need to use an external receiver. In this case it would be the clonix 2e.
This would then get wired as followed.
Terminal 50 = - negative 24v/ground
Terminal 51 = +positive 24v
Terminal 60 = Common ©
Terminal 61 = Normally open (NO)
RE: Thalia P - Wireless control board module - by SamA - 02-03-2023, 03:17 PM
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,784 03-02-2025, 12:24 PM
  BFT Thalia no power on accessory ports (50, 51) tjomk 2 4,285 22-10-2024, 02:54 PM
Last Post: Bigmac3112
  BFT deimos smoke from board stanli200188 1 3,940 05-03-2024, 04:17 PM
  Thalia - Photocell Close J to the D 1 3,665 19-01-2024, 09:54 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 12,967 24-08-2023, 01:38 PM
  thalia error code 3h 35/37/38 detritus 1 5,893 05-01-2023, 11:54 AM
  Er 10 code on RIGEL 6 control unit Eddiew 1 6,835 05-01-2023, 11:53 AM
  BFT Thalia button djbananas 3 9,180 19-04-2022, 09:14 AM
  BFT Thalia GSM gate opener SunnyB1 1 6,252 07-03-2022, 10:58 AM
  Lux/Thalia P ersl error Dava12 0 4,664 13-12-2021, 09:35 PM
Last Post: Dava12
