  • 25 Vote(s) - 2.96 Average
BFT SubR not opening/closing sometimes
(05-01-2023, 01:06 PM)Jimmyboy4 Wrote: Hi Joe,
thanks for your reply. It's the underground Sub R motor with slowdown facility fitted in 1996. The good news is that as the temperature has now risen to above zero they are working again as before and opening and closing fine. The only issue I have had for some time is that on closing, one leaf stops mid cycle then starts again and closes. I'm wondering if it needs bled and/or topped up with fluid.
Jim
Hi Jim,
Usually if the gate stops halfway through a cycle this is due to resistance, I would recommend increasing the force via the control board incrementally or you could top the fluid up to make sure the hydraulic pressure is where it needs to be to bypass certain resistances.
Kindest Regards,
RE: BFT SubR not opening/closing sometimes - by SamA - 09-01-2023, 10:29 AM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,054 14-06-2024, 12:12 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,464 04-01-2024, 10:21 AM
  BFT opening problem 8 56,195 08-08-2023, 02:14 PM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 8,089 23-05-2023, 03:48 AM
Last Post: Bushpig
  Gates not fully closing stefen1978@hotmail.co.uk 2 7,650 10-10-2022, 10:07 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 20,861 19-08-2022, 09:30 AM
  LUX G BT 2B not closing properly since manual override swinnie 1 5,205 03-08-2022, 01:44 PM
  Slider closing then reopens 8" MWJONES 4 26,295 14-03-2022, 12:04 PM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 6,153 07-03-2022, 11:24 AM
  Phobos reversing after closing Sim75 0 4,079 21-05-2021, 07:04 AM
Last Post: Sim75
