  • 19 Vote(s) - 2.47 Average
PHOBOS N Manual Overide Problem
(02-12-2022, 04:42 PM)Dazrob Wrote: Hi, I have PHOBOS N motors and I can't get one of the motors to unlock with the key. When I turn the key the nothing happens, on the other motor you can feel it release then it opens. Any help would be appreciated.
Good Morning,
Its more than likely that the manual release mechanism inside is jammed. I would recommend running the gates to different positions automatically then trying to release it. You could also try and put some sort of WD40 if it is stiff. Lastly, try and push the gate back and forth while turning the manual release. It may be that the mechanism is fully seized and needs replacing.
Kindest Regards,
PHOBOS N Manual Overide Problem - by Dazrob - 02-12-2022, 04:42 PM
RE: PHOBOS N Manual Overide Problem - by SamA - 05-12-2022, 09:32 AM
RE: PHOBOS N Manual Overide Problem - by Dazrob - 05-12-2022, 06:43 PM
RE: PHOBOS N Manual Overide Problem - by Dazrob - 06-12-2022, 07:29 PM
  Bft gate problem djkokalis 1 5,621 14-02-2024, 12:39 PM
  Phobos motor movement erratic Caesium 1 4,192 24-08-2023, 01:39 PM
  BFT opening problem 8 56,195 08-08-2023, 02:14 PM
  LUX G BT 2B not closing properly since manual override swinnie 1 5,205 03-08-2022, 01:44 PM
  Phobos N L BT one leaf won’t open BigJC 0 5,119 11-06-2021, 01:33 PM
Last Post: BigJC
  Phobos reversing after closing Sim75 0 4,079 21-05-2021, 07:04 AM
Last Post: Sim75
Smile Rigel 5 Manual override Stramorebees 0 11,918 20-09-2020, 12:03 PM
Last Post: Stramorebees
  Gate won't close on manual or auto Baz1981 0 7,774 23-06-2020, 05:27 PM
Last Post: Baz1981
  bft hydraulic gate problem richh 4 28,270 23-12-2019, 04:36 PM
  Strange opening problem Baz1981 4 88,915 15-07-2019, 08:39 AM
