  • 23 Vote(s) - 3.52 Average
Came FROG A noisy
The right hand leaf of my swing gates was occasionally stopping mid travel during closing (opening was fine). I noticed the motor is making a "creaking" noise when in operation (the other side is just a low hum noise).
I've adjusted the transformer power to number 4 position (it was on 3 previously). This has resolved the gate stopping, for now at least, but it is still making the same noise.
I also checked both capacitors, which are reading around 15.9uf.
The whole setup has been in place for around 7 years with no major issues.
Questions I have please:
1. I suspect the motor is on it's way out - but does the noise indicate anything else? The gate when released moves very smoothly by hand.
2. Does the transmission lever on these simply pop out upwards? Any tips on how to remove it - i.e. hammer/crowbar, as it seems pretty wedged in place?
3. If I buy a replacement motor, are the steps as follows:
a) 4 bolts to remove and replace with new motor
b) Put transmission lever back in place with some white lithium grease added
c) I can unplug the cable going to the old motor and plug it into the new one
d) Adjust limit screws to the same positions as the old motor had
I've attached an image of the motor. I've been putting white lithium grease every year on the 2 points circled in Blue. Is this ok?
The part circled in red I believe is a grease nipple. How often should that be greased and could a lack of grease be causing the creaking noise?
A lot of questions - my apologies! But appreciate any/all advice.
Thanks.
Came FROG A noisy - by fezster - 22-09-2022, 12:16 PM
RE: Came FROG A noisy - by SamA - 30-09-2022, 03:16 PM
Last Post: nuphor
  CAME Frog AE-p24 kit Push Button Stuartl 2 7,501 20-10-2023, 08:57 PM
Last Post: Stuartl
  Frog A24E motor stopping SW1806 7 16,739 24-03-2023, 02:58 PM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 18,035 23-02-2023, 01:09 PM
  Came FROG - one leaf occasionally does not open fezster 3 13,281 03-08-2021, 10:07 AM
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,805 11-04-2018, 07:25 AM
  Frog - ZA3: gates won't open BarryD 0 12,098 15-06-2016, 01:34 PM
Last Post: BarryD
  Frog p 230v or 24v ? Emilyjudy 5 40,409 08-03-2014, 01:32 AM
Last Post: stephen70
  CAME Frog and Daitem 902 jderuk 1 22,089 08-03-2014, 01:17 AM
