  • 16 Vote(s) - 2.94 Average
water damage to FAAC photocell
It worked, I installed the new photocell but notice the Rx end has one light only, so went back and opened the photocell and found the two of the four cables rubber casing were damaged with wires broken 10 cm from the end inside the metal post.  Luckily there was plenty of cable length, so  cut off the damaged section and connected fresh end of cables and all is good.  Thank you JoeF! Smile
water damage to FAAC photocell - by Rajab - 11-07-2022, 04:21 PM
RE: water damage to FAAC photocell - by JoeF - 12-07-2022, 11:38 AM
RE: water damage to FAAC photocell - by Rajab - 12-07-2022, 01:39 PM
RE: water damage to FAAC photocell - by Rajab - 17-07-2022, 08:15 PM
RE: water damage to FAAC photocell - by Michael - 18-07-2022, 09:00 AM
  FAAc xp20d wiring Neil Young 4 6,118 04-02-2025, 12:08 PM
Last Post: Neil Young
  FAAC gates out of sync TheDock 1 3,452 21-08-2024, 12:21 PM
Last Post: TheDock
  Faac 452 pcb board benner91 2 6,795 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 8,272 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  Photocell Problem marcoos_1 4 28,735 04-01-2024, 10:23 AM
  FAAC E124 fault 05 allan@amtas.com.au 0 3,601 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 9,110 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 4,429 23-06-2023, 03:19 PM
Last Post: Alpin
  FAAC Photocells mmc1977 3 8,378 02-05-2023, 12:37 PM
  Proteco gates with photocell problem. Shane1 0 4,179 09-10-2021, 07:56 PM
Last Post: Shane1
