  • 22 Vote(s) - 2.91 Average
FAAC foundation plate
(14-06-2021, 08:05 AM)mun31 Wrote: Hi
I'm looking at getting a FAAC 740 for our sliding gate. The installation manual suggests pouring cement into the foundation and allowing the cement to set with the foundation plate bolts in position, but our driveway is already entirely concreted. Doe anyone know if there are ways to bolt the foundation plate down instead? It's not clear from the manual if the provided bolts can be fastened into concrete.
In fact, I'm not sure what the purpose of the foundation plate is when the motor is designed to be held up by the 4 bolts (and their nuts and washers). The plate seems to act like nothing more than a template for placing the bolts.
Any thought appreciated.
I hope you are well. The foundation plate is needed to secure the actual motor to the ground. The plate will be cemented into the ground which will make it secure, the motor above will then be bolted to this. You will need the cement method to ensure stability of the motor in operation. I would only advise to install as per the manufacturers instructions, as you will void the warranty of the kit if you do not follow them.
Kind regards
- Jamie
FAAC foundation plate - by mun31 - 14-06-2021, 08:05 AM
RE: FAAC foundation plate - by JamieF - 30-06-2021, 09:33 AM
  FAAc xp20d wiring Neil Young 4 6,155 04-02-2025, 12:08 PM
Last Post: Neil Young
  FAAC gates out of sync TheDock 1 3,474 21-08-2024, 12:21 PM
Last Post: TheDock
  Faac 452 pcb board benner91 2 6,832 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 8,338 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  FAAC E124 fault 05 allan@amtas.com.au 0 3,627 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 9,149 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 4,461 23-06-2023, 03:19 PM
Last Post: Alpin
  FAAC Photocells mmc1977 3 8,414 02-05-2023, 12:37 PM
  water damage to FAAC photocell Rajab 4 9,563 18-07-2022, 09:00 AM
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 4,196 04-10-2021, 02:34 PM
Last Post: wildfig
