  • 30 Vote(s) - 2.97 Average
No movement at all
Hello
You should see that the first 3 LEDS are on and the 4th is only on when a wired input connection commands the gate (I.E. open, stop and close). If you have connections going into terminals 23 and 25, you will need to check these. This is the emergency stop input, this input will need a closed circuit to allow the gate to function. On the 4th L.E.D, the step by step or P.P. input, this input should have an open circuit, if the LED is on there is a closed circuit and this could be 'holding' a close input on the gates. These two connections will need to be investigated for any shorts or breaks in cabling which could be causing your issue.
No movement at all - by Familyman - 30-06-2020, 07:19 PM
RE: No movement at all - by RyanB - 27-07-2020, 10:42 AM
