  • 17 Vote(s) - 2.47 Average
Chamberlain Liftmaster Professional Problem
Help!
I live in a house with a Chamberlain Liftmaster (Professional) fitted since new -so about 20 years old- to a double size up-and-over garage door. It has always given fault-free operation. However I have now found that it doesn't respond to either of my remote fobs (4330E type) and a change of batteries has not improved things.
It works perfectly using the wired open/close button inside the garage, but an attempt at reprogramming the fobs to see if they had 'lost' the code had no response.
As I think it would be unlikely that the fobs have both failed together, I am thinking there must be a fault occuring in the "receiver section" of the motor - but as you can probably tell, I am no expert!
Is it possible for me to replace the receiver unit alone or would the whole motor unit need to be replaced by a modern equivalent? Can this be done by an amateur?
Thanks.
Chamberlain Liftmaster Professional Problem - by Upandover - 26-04-2020, 05:17 PM
  LiftMaster 800 Belt Richard B 2 13,283 20-10-2021, 05:16 PM
Last Post: Richard B
  2 x LiftMaster 800 garage door openers Richard B 2 16,463 07-10-2021, 03:54 PM
  Problem with Sly300 CB22 not closing Del 1 22,802 21-03-2014, 06:09 PM
Last Post: Del
  1000A remote problem macallan 5 47,175 24-04-2013, 08:30 AM
Last Post: binsonwilles
  LM 800a lamp problem jgj 1 23,136 23-07-2012, 09:41 AM
  Liftmaster 5580 - Overunning Limit Stops pwrycroft 2 28,033 22-12-2011, 11:59 AM
Last Post: pwrycroft
