  • 458 Vote(s) - 2.84 Average
ML850. Setting the Limits
Brillopad Wrote:I have installed an ML850 on a client's cantilever garage (Type A in the manual). Having read the instructions numerous times and gone through the automatic set limits and manual set limits I am at a loss as to why it won't work.
I open the light cover compartment, press the black button until the yellow light blinks slowly, then I use the black button to open the door up to the position I require, then I use the remote key (or the hard wired pad) to set the limit.
According to the instructions the door should then close and open up to the set position. But all it does is flash once when remote key is pressed then 5 secs later flashes 11 times.
When the door is closed, the remote key or the wired pad will open the door smoothly, but will run the door against the doors physical stops then shut off. Another press of the remote only makes the unit try to open the door further, but shuts off on force limit.
Your help with this matter would be much appreciated.
Hi, I suggest you call the chamberlain helpline on : 0800 317 847, we can't offer support on the motorlift range as we deal with Liftmaster Professional garage door openers.
ML850. Setting the Limits - by Brillopad - 06-04-2009, 08:14 AM
RE: ML850. Setting the Limits - by easygates - 22-04-2009, 04:50 PM
RE: ML850. Setting the Limits - by Doorman - 03-11-2009, 02:49 PM
  Motor lift ml850 protector system rondickinson@btinternet.com 1 17,531 15-04-2019, 09:34 AM
  ML850 no longer operates rivergo1d 1 25,856 12-04-2018, 04:52 PM
Last Post: Tim
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 27,363 19-01-2016, 07:10 PM
Last Post: DJBenz
  ML850 Remotes don't work huckit P 1 22,917 06-01-2012, 09:59 AM
