  • 29 Vote(s) - 3.14 Average
391 not responsive
Hi, I have a FAAC 391 swing gate opener set, which has the E0245 board. All's been fine for months, but the other day the gates spontaneously opened, then after that won't close with the key switch, fobs or keypad.
I removed the radio module in case it was receiving spurious radio signals from the fobs or keypad, no change - the key switch - which is across Open A, does nothing. I've tried shorting the switch pins out on the board in case its a switch/wiring issue - no change.
I did a factory reset, ran the auto setup which worked fine, then set the logic to EP, all looks OK, but still no response from either OPEN A or OPEN B pins.
Any ideas please?
A
391 not responsive - by alinton - 27-01-2020, 10:55 AM
RE: 391 not responsive - by AccessControlLtd - 01-04-2020, 12:33 PM
RE: 391 not responsive - by JoeF - 02-04-2020, 11:29 AM
