  • 21 Vote(s) - 2.81 Average
Liftmaster CB1 gates started to open themselves
RE: Liftmaster CB1 gates started to open themselves - by pronosoft - 01-01-2020, 09:43 AM
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 1,711 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,148 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  My swing gates are stuck at 50% open jctrotting 1 4,558 11-04-2024, 08:11 AM
  Liftmaster LA400 Defender 6 23,522 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 22,356 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 20,151 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 24,201 22-02-2021, 08:48 PM
Last Post: russ
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,622 14-04-2020, 01:45 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,132 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB1 How to learn the gates telnet123 1 18,636 30-04-2018, 01:45 PM
Last Post: Tim
