- 17 Vote(s) - 2.76 Average
- 1
- 2
- 3
- 4
- 5
Liftmaster CB1 gates started to open themselves
Threads: 3
0
(24-12-2019, 09:25 AM)telnet123 Wrote: (23-12-2019, 04:16 PM)RyanB Wrote: Hello,
There could be a possible cable break from the keypad to the control panel which could be shorting and causing the open signals. I would recommend disconnecting your keypad from the system and monitoring whether the random activation continues. If the random activation does continue it could be a fault on one of your remotes or the receiver unit. Re instate the keypad and remove the memory of the remotes, if this stops the random activation, reprogram the remotes one by one and monitor until you find the remote which is causing the issue.
I hope this if of some assistance. Thanks RyanB - Are you able to give some guidance on what terminals I need to disconnect for the keypad?
Ok - after speaking to your helpful support team it was mentioned moisture could be the cause, so I have cleaned and dried out the "weatherproof" box containing the CB1 board and the SRS switch and sealed any holes with sealant. This appears to have resolved the issue. I now have another issue where only one gate opens after reprogramming. I'll raise another post for this.
| Messages In This Thread |
RE: Liftmaster CB1 gates started to open themselves - by telnet123 - 29-12-2019, 09:37 AM
| Possibly Related Threads… |
| Thread |
Author |
Replies |
Views |
Last Post |
LiftMaster SL400EVK & 722e Failsafe |
Tucks27 |
4 |
350 |
Yesterday, 10:52 AM
Liftmaster MYQ Internet gateway |
koen_dc |
4 |
27,098 |
05-10-2024, 01:30 PM
Last Post: Arnold Pow
My swing gates are stuck at 50% open |
jctrotting |
1 |
4,218 |
11-04-2024, 08:11 AM
Liftmaster LA400 |
Defender |
6 |
22,300 |
03-08-2023, 12:26 PM
Last Post: Torantrieb
odd liftmaster scs300-24 |
scopie88 |
3 |
21,474 |
13-04-2022, 10:20 AM
Liftmaster MYQ Internet Gateway Registration/Connection issues! |
Carmody |
0 |
19,388 |
09-03-2021, 02:46 PM
Last Post: Carmody
Advice on new gate install - LIFTMASTER LYN424 |
Leeb |
1 |
23,485 |
22-02-2021, 08:48 PM
Last Post: russ
Sliding gates are opening/closing like someone is going in /out. |
gandreja |
3 |
14,111 |
14-04-2020, 01:45 PM
Chamberlain Liftmaster gate problem CB1 |
Armstrong |
2 |
35,633 |
13-06-2019, 11:46 AM
Last Post: Pop Alexandra
CB1 How to learn the gates |
telnet123 |
1 |
18,338 |
30-04-2018, 01:45 PM
Last Post: Tim
