  • 534 Vote(s) - 2.96 Average
Remote Control
David Brisland Wrote:did you get this problem solved as i am having exactly the same problem
Hi, Make sure the radio card is connected correctly and all pins are connected. Try taking it out and re-inserting it just to make sure you have it plugged in correctly.
Have you tried another remote control? Or replaced the batteries in the one you are using?
Have you set up the photocells? you do this by turning the power off, placing a jumper over the terminals labelled "Save Fail Safe Photocells", then turning the power back on and removing the jumper after 15 seconds.
Hope this helps,
Remote Control - by Steve - 08-12-2008, 04:49 PM
RE: Remote Control - by Mark - 09-12-2008, 01:21 PM
RE: Remote Control - by Steve - 09-12-2008, 01:54 PM
RE: Remote Control - by Golfmadnut - 28-04-2016, 08:04 PM
  Control Unit Not Working mtuk100 0 41,985 10-10-2019, 03:14 PM
Last Post: mtuk100
  Which original remote control is suitable for board CB124 Evan 3 14,474 20-06-2019, 04:26 PM
Last Post: Devs
  Remote problem Nickhh 1 12,397 30-09-2014, 04:48 PM
  lyn300 control panel andy15 1 14,987 13-12-2011, 09:59 AM
  Liftmaster 800 Remote KevinR 1 17,641 07-10-2011, 10:27 AM
  CB11 control box Intercom release button not working Moreteyne 0 10,654 14-09-2011, 03:14 PM
Last Post: Moreteyne
  Lost garage remote controller 1 19,592 25-01-2010, 06:12 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,658 28-06-2009, 10:19 PM
Last Post: Sparky
