  • 561 Vote(s) - 2.96 Average
single & double gate operation
Hi Buzby,
Sounds like you probably have the BFT hydraulic rams that only have locking in one direction or possibly not locking at all. Its risky fitting rams that lock in the closed direction if fitted to wooden gates because quite often the bypass valves will blow when a strong gust of wind catches the gate leaf!! Rendering the motor buggered!! your only feasible option is to fit a magnetic lock coupled with a drop bolt, that would keep both leafs securely locked shut.
if you look underneath the ram you should see an information sticker showing model numbers. if you can get that info, and the control panel you have is the best you can get BFT wise, the Rigel 5 will do everything you want and more!!
Download the tech manual here:
http://www.gates.uk.com/products/install...panels.asp
Regards,
Carl
single & double gate operation - by Buzby - 03-02-2009, 10:44 PM
RE: single & double gate operation - by Home IQ - 05-02-2009, 09:37 AM
RE: single & double gate operation - by Buzby - 06-02-2009, 12:04 PM
RE: single & double gate operation - by Home IQ - 10-02-2009, 12:18 PM
RE: single & double gate operation - by Buzby - 10-02-2009, 12:33 PM
RE: single & double gate operation - by Home IQ - 12-02-2009, 06:40 PM
RE: single & double gate operation - by Buzby - 22-02-2009, 04:58 PM
RE: single & double gate operation - by Buzby - 09-06-2009, 11:20 PM
RE: single & double gate operation - by David Murray - 04-09-2009, 06:18 PM
RE: single & double gate operation - by easygates - 12-01-2010, 02:46 PM
  BFT Gate Motor - Not working elyoussef.ali 1 6,083 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 1,784 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,693 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,784 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,440 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 4,918 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,484 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,144 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 2,846 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 16,678 11-04-2024, 08:08 AM
