  • 50 Vote(s) - 2.84 Average
BFT Rigel 5--how to set swing gate slow close at end ?
BFT Rigel 5 with with two electromechanical operators Swinging gate inherited from the previous home owner, left no clue of what it is  or what so ever.
I suppose this is called End-of-run speed slow-down? Basically it used to slow down a lot just before both gate reaching the fully closed position, and make a gently touch to close completely.
Here is how is started, initially the one the gate ( Motor1) begin to close slower than it used to be, and this causes the other gate (Motor 2) to reach the fully stop position earlier.
I thought the simple solution was to increase the Leaf 2 closing delay time, however, at preset menu, I set whole thing to Automatic operation,which must changed all the other parameters and logic to Ar.
Just wondering if anyone can shade some light on how to prevent gates from slamming during closing process?
There are seems to be "Slow down time", Braking, and some other setting to change in Logic menu,
I am positive that the gate used to behave like they have braking action when they were about getting to the Fully closed position.
Much Appreciated if anyone can pointing some right directions, as the door would bang at the ground anchor stopper as they missed the slow-down effect.
(08-07-2019, 05:16 AM)jojo351 Wrote: BFT Rigel 5 with with two electromechanical operators Swinging gate inherited from the previous home owner, left no clue of what it is  or what so ever.
it possibly could be due to the size of the gates and the function not being as effective over time.
it could also be a glitch on the panel.
do you also have physical limit switches in the top of your motor.
are they still working?
They don't have limit switches, somehow increase the motor torque and slowdown time/show down torque works. I figured that increased Motor torque would amplify the effect of slow down effect, given the slow down torque set to maximum of 99. One thing I am not sure is the braking effect and open/close impulse. Manufacturer, for some reason, not willing to explain more about these effect to me.
Replaced the motor running capacitors both 8uF seems to bring the responsive force back and immediately I could see the slow down effect towards the end--- however, it seems only visible for the motor 2 or leaf 2 of the swing gates,  and the Motor 1 does not show noticeable slow down period and it just stop while opening and slams slightly when closing.
The motor shows maximum of 2500N of torque, I set the system to run at 50% of total motor torque,
Slowdown is set to 6seconds, to give about 600mm of slowing space,
Slowdown torque set to 11%,  according to the manual this is below 400N, (400N/2500N)
I just could not find anyone or any other explanation about Rigel 5's manual here in Australia.
Set the slow-down to approach time from 0 to 20 seconds. The slow-down
time is subtracted from the work time.
NOTE: it is advised to activate timing.
NOTE: only use this function when limit switches are fitted.
NOTE: Do not use with hydraulic motors.
t numerically from 1% to 99% the value of motor torque during slowdown time.
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,158 11-08-2025, 04:12 PM
  BFT Rigel 5 Talonfinger 0 2,195 26-03-2025, 12:07 PM
Last Post: Talonfinger
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,231 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,574 03-02-2025, 11:29 AM
Last Post: Sootylfc
  BFT Rigel 5 - Phot message robs999 2 5,062 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,366 30-10-2024, 12:54 PM
Last Post: Vaf888
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,395 15-10-2024, 10:37 AM
Last Post: Sootylfc
