  • 81 Vote(s) - 2.84 Average
BFT Rigel 4 receiver signal problem
Hi, I am hoping someone can point me in the right direction. I have a Rigel 4 with RE01 receiver. Worked fine for 15 years and now suddenly key fob will only work if I go within 1m of control box. So far I have tried;
1) Change key fob battery
2) Try 2nd fob
3) Change aerial (seemed the most likely source of the problem)
Still same problem - neither better nor worse.
I am reasonably knowledgeable about electronics - but not about these control units.
Where should I look next?
Receiver board? Can you even still get these REO1 boards?
The whole control / receiver board looks in great condition.
Any suggestions welcomed.
Many thanks,
Mike
Ok quick update - as someone else may have this issue -
before replacing plug-in receiver with new generation (and transmitters) at some expense - I decided to try and see if it was just the plug in board connection that had tarnished over time (16 years old). Well removing and reseating the receiver board did indeed fix the problem. Now which joint got remade in the process is anyone's guess - it could have just been a solder joint that got remade. But its all working, transmitter range back to 30m rather than 1m ! Hope that helps someone.
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,693 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 1,982 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,217 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 4,591 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 4,813 30-10-2024, 12:54 PM
Last Post: Vaf888
  Gate radio receiver not working Zhymke 0 2,846 23-05-2024, 06:35 PM
Last Post: Zhymke
  BFT Rigel 5 issue Adamit 0 2,643 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 17,783 04-05-2024, 12:47 PM
Last Post: Alee
  Bft gate problem djkokalis 1 5,301 14-02-2024, 12:39 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,094 04-01-2024, 10:21 AM
