  • 162 Vote(s) - 3.04 Average
Rigel 5 and sub r
Khi new here  I was wondering if anyone point me in the right direction on how to program check the program of Rigel 5
Problem I’m having is one of the gates works correctly and one gate just move a tiny bit in closed or open  Motor was taken out and as been test at  Electric motor repair shop came back Woking ok
Could  it be the capacitors or
programming of the gate control as the Son try adding new remotes Controls
Hi Steve,
Thank you for your enquiry, i will post below the manual for the Rigel 5 board which will help with programming and error codes. I would advise you to check the motor output terminals on the board if the motor has come back from testing as not faulty. If you are getting the correct voltage once a command to the gates have been given then i would be checking the capacitors, this can be done by swapping the capacitor from the working motor to the motor that isn't working. If the fault moves from motor to motor then we know that this is the problem. Hope this helps and if you need any more assistance don't hesitate to contact us.
http://manuals.easygates.co.uk/PDF/misc/bft-rigel-5.pdf
Kind regards
Tim
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,428 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,195 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,574 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 5,061 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,365 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,890 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 18,210 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,464 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,936 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 7,229 05-01-2023, 11:53 AM
