  • 198 Vote(s) - 3.01 Average
Problem with delay time CB11
I have motors Liftmaster SCS300 and controller CB11.
Potentiometer for delay time is set on max (PT1).
Whan wings closing, everything is fine. Delay time is about 10 s.
But whan wings in opening, both wings move in opening at the same time?!
I try with reset controller CB11, but nothing changes.
Please help.
(25-05-2017, 12:50 PM)milan Wrote: Hi,
Please help.
Hello Cool
When amending any of the settings on the CB11, you will need to power down the board first. I would suggest turning the bipart delay off (fully anti-clockwise) while the CB11 is powered up then power down the board and adjust the bipart delay to around half way. Switch the control board back on and see how you get on. if the delay isnt enough then power down again and adjust some more (clockwise). The bipart delay potentiometer adjusts the opening delay time between 1-3 seconds and closing between 0-20 seconds.
I hope this helps. If this still doesn't work or you need any further assistance please give me a call.
EasyGates.co.uk
EG Direct - Trade only
Problem with the coin comparator/optics. Error 21 extra coin in not out, so not hopper. You would get the same error if you removed the CC/optics and turn the power on. Should be a problem with the optics, or wiring. Maybe coincidental with the battery change, should not be related to the battery change. Plus I think I have cleared that error by turning the jackpot reset key and opening and closing the door a couple times?
Tony
  CB11 Multiple Keypad support Pigsfoot 1 5,636 12-08-2022, 08:14 AM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,133 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  LiftMaster SUB300M + CB11 fault jonesy1991 0 12,604 25-01-2016, 02:51 PM
Last Post: jonesy1991
  Opening delay on SCS300 (CB124 board) willows79 0 10,616 02-12-2015, 09:45 PM
Last Post: willows79
  CB24 delay to close random fault stuartdsutton 0 10,180 23-09-2015, 11:38 AM
Last Post: stuartdsutton
  CB11 controller BrianP 2 17,463 16-09-2015, 08:58 AM
Last Post: Gateguy
  CB22 problem??? Bakota 0 10,933 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 12,395 30-09-2014, 04:48 PM
  liftmaster CB11 hold gate open problem sparkey 5 38,182 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 14,352 08-05-2013, 11:32 AM
Last Post: Mark
