  • 224 Vote(s) - 3.1 Average
Mindy A60 and closing issue
Hi Guys sorry for the first post being this ,I've got a Mindy A60 that has a timer opening at 6.30 am (Gates open) and should close at 21.30.
what's happening is the gates open as they should but when the timer drops out (I can see and have metered it the timer falls away and goes open circuit, the gates don't shut. But to make matters worse not all the time,confused .... yeah me too. If I momentarily short out pin 27 (close) it closes.
I was going to put another timer relay in say at 21.40 just to pulse it closed, but that defeats the object.
All safety features are clear so I'm a little confused.
I also have a ground loop hitting the same open input but that's clear and just to be sure I've put two diodes just in case of feed back.
Thanks again for reading and any help would be great.
Gary
(28-02-2017, 11:35 PM)alarmeng Wrote: Hi Guys sorry for the first post being this ,I've got a Mindy A60 that has a timer opening at 6.30 am (Gates open) and should close at 21.30.
Gary
you could check all safety features /loop/photo/stop.
bridge all nc contact with com temporarily and press handset to close the gate
regards
Best Regards
Tom
Gary
Hi Gary,
Couple of questions for you.
Have you got automatic closure set on the panel?
What position are your dip switches in currently?
  Nice MC824H Set Up issue dmrgate 2 8,375 10-12-2024, 10:31 AM
Last Post: dmrgate
  Potential Encoder Issue Ben_wing 1 3,928 09-12-2024, 12:57 PM
  IT4WIFI Homekit Issue anx10us 4 10,817 01-10-2024, 10:04 AM
Last Post: Gsr341
  Nice robus not closing Dantay 1 5,204 27-09-2024, 10:17 AM
  Nice MC800 Wiring issue Adamzsite 2 6,359 05-03-2024, 04:37 PM
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 11,408 04-01-2024, 10:06 AM
  ROBUS 400 OPEENING CLOSING ISSUES warren203 1 5,707 08-08-2023, 02:16 PM
  NICE MC800 for failed A60 mindy bg148 2 8,848 17-06-2022, 12:25 PM
  Nice TOO7500/ Mindy A60 Installation Problem Woody 1 9,912 22-08-2020, 02:31 PM
Last Post: Woody
