  • 498 Vote(s) - 3.01 Average
New daitem / logisty wireless intercom systems KIT SC902AU
Has anyone installed or come across the new daitem / logisty wireless intercom systems, KIT SC902AU.
What exactly have they changed?
Is it just a re-design of the handset?
or have they changed the range reception of the units?
We install alot of the older kits and I am interested to know what they have done.
Really want to know if they have improved on the range as with some installs they are not practicable if you don't have a good line of sight with the transmitter unit white box and the handset in the house.
Such things as trees walls etc can dramatically reduce the range.
The Daitem website is useless with practically no new info.
New daitem wireless kits
[Image: 4244__IMG]
The New Daitem Kits have redesigned the Handsets and now use a DECT system which runs on a different code hopping frequency. This now allows the single unit to control upto 4 call stations as standard and should be a clearer signal as the handsets need to logon to the digital system. We have a unit installed on our entrance gates and have found no difference to the previous kits ie it works exactly the same with our electric gates. As this is a new system we have not had any feedback on range available etc and any problems all i can say is it works the length of our building approx 50m.
Sorry i dont have any further tests but will post findings as and when we have more data available.
hello my name is Maurice I am the field technical and training manager for GM Techtronics Ltd we are the suppliers of Daitem equipment to easy gates
i have done extensive range test with the new equipment as i have also done with the old kit and had varied results there are many changes i.e. its a digital system not analogue like the old kit so field results will be different i have uploaded the various brochures and manuals for you please don't hesitate to call if you need any more help our numbers are John in technical 08448246692 or Maurice 07764905997.
.pdf   NEW DAITEM ISF3 SALES BROCHURE.pdf (Size: 1.05 MB / Downloads: 2,944)
.pdf   ISF3 PROFESSIONAL CATALOGUE.pdf (Size: 2.87 MB / Downloads: 2,774)
.pdf   DAITEM ISF3 INSTALLATION GUIDE.pdf (Size: 6.69 MB / Downloads: 3,471)
.pdf   DAITEM ISF3 USER GUIDE.pdf (Size: 2.29 MB / Downloads: 2,925)
(29-06-2011, 04:41 PM)maurice Wrote: hello my name is Maurice I am the field technical and training manager for GM Techtronics Ltd we are the suppliers of Daitem equipment to easy gates
Hi Maurice
I have been wondering, what is the max distance for this new line of Daitem digital wireless system, as i have an gate automation upgrade and gate access, and would like to use this product, the only problem is the distance from gate to house is roughly 150 yrds
  Daitem sc901 au Ketton 1 801 25-11-2025, 01:04 PM
Last Post: GM Techtronics Ltd
  GSM intercom DBElectric 1 5,288 17-06-2022, 12:30 PM
  Logisty LCA01F/LCB01F opens only one gate Woz1001 1 9,116 24-05-2021, 10:25 AM
  Daitem gate control novice help needed... TimRW 0 7,668 29-03-2021, 07:58 PM
Last Post: TimRW
  Daitem intercom not working mikecymru 1 23,403 19-12-2020, 08:56 PM
Last Post: Andy
  Daitem SC900AX Not Working - Help Please! Eskimo 0 28,150 09-04-2018, 08:04 PM
Last Post: Eskimo
  AES DECT GSM Intercom landline dial programming manchester_sparks 0 18,746 18-03-2018, 09:02 PM
Last Post: manchester_sparks
  Handset system DAITEM D5131GB Carlo 1 41,593 18-01-2017, 10:49 AM
  Daitem D5300 is it compatiable with SC902AU steve redwood 2 29,236 02-01-2015, 02:55 PM
  Daitem D5731gb system royaugout 1 28,073 02-01-2014, 04:15 PM
