  • 262 Vote(s) - 2.76 Average
BFT Altair-P with Phobos motor doesnt stop after closing
Hi All!
This is my first post in the forums.
Everything was working ok until yesterday. Since yesterday after the doors open or close the motor of phobos doesnt stop, it continues to work.
I have to press again the remote button in order to stop.
Is there any way that i can configure this myself through the manual programming? or not?
Its the first time that i mess with this, so sorry for the noob question...
P.S. I have downloaded the manual from here: http://manuals.easygates.co.uk/PDF/bft/A...h06-07.pdf
Here are the photos of what i have.
[Image: 20141122_122922.jpg]
[Image: 20141122_122936.jpg]
I used the manual and got into the menu.
I saw that operation time for some reason is 180..I measured the gate time to open/close and i have to put it to be around 24 secs.
I tried to change the value of 180 with the 2 press buttons but no luck, they dont change.
Do i have to put a jumper or something?
Hello
To me it sounds like there is an issue with the control panel not remembering the length of run time, when you go back to the display of the run time is it still set to the same as what you programmed in or is it a different number?
(22-11-2014, 11:49 AM)earthdog Wrote: Hi All!
Hi!
The setting originally was 24 secs.
At some point of time the gate started not to stop operating on open/close
I opened the box and entered the menu following the manual instructions.
There i saw the setting to be 180. And it is still 180. The issue is that i cant change the number (180) to what i want....
  BFT Gate Motor - Not working elyoussef.ali 1 6,081 11-09-2025, 10:15 AM
  BFT Altair-P "Phot" message. How to bypass/Test? AdamC 0 1,354 16-07-2025, 06:36 PM
Last Post: AdamC
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,137 14-06-2024, 12:12 PM
  BFT Eli 250 24V motor running, no movement. Bjorn 1 6,660 30-01-2024, 07:45 PM
Last Post: Peejay
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,086 04-01-2024, 10:21 AM
  smart relay BFT ALTAIR halt23 1 3,416 13-11-2023, 11:45 AM
  smart relay BFT ALTAIR halt23 1 3,262 13-11-2023, 11:45 AM
  Phobos motor movement erratic Caesium 1 3,868 24-08-2023, 01:39 PM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 7,648 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,273 09-01-2023, 10:29 AM
