  • 230 Vote(s) - 2.73 Average
Use GSM switch with liftmaster sly 500
I have to buy 3 more remotes so everyone in the house has one. Is it possible to use the GSM switch you sell (GM Techtronics GMT-RC01 GSM Switch) to work with the SLY 500 kit? If so how is it wired to the CB224 board.
Thanks for your help
Hi, Yes our RC01 GSM switch will work with your system, however you will need a separate power supply as these only operate on 12V and the CB224 panel has a 24V power output. Please see attached diagram in relation to your enquiry! If you need any more details, please get in touch with us on 0845 054 5070.
Kindest Regards,
Easygates Technical
(15-05-2013, 04:52 PM)bigone001 Wrote: I have to buy 3 more remotes so everyone in the house has one. Is it possible to use the GSM switch you sell (GM Techtronics GMT-RC01 GSM Switch) to work with the SLY 500 kit? If so how is it wired to the CB224 board.
.pdf   RC01 CB224.pdf (Size: 199.87 KB / Downloads: 1,133)
Thanks very much for your prompt reply
