  • 278 Vote(s) - 2.91 Average
Gate not always shutting - LUX FC-2B
If we pause this gate on it's opening cycle, it always closes properly. If we let it open fully (without interruption) then SOMETIMES it does not close properly.
Is this about "opening pressure"? Or do we need to fit an opening limit stop (like a large rock?)?
Thanks!
(08-04-2012, 09:17 AM)ccl Wrote: If we pause this gate on it's opening cycle, it always closes properly. If we let it open fully (without interruption) then SOMETIMES it does not close properly.
Thanks!
This Gate System Will need open and close stops or it does not have a fixed possition to open too and can over run resulting in the gate not closing properly. This is a general rule for most Arm type motors that they need fixxed stops to move against so they cannot go past there limits. Using this system without the stops may cause damage to the hydraulic seals in the motor and would be a very expensive repair. I would disable the system and get stops fitted then reprogramme the system to work to the new limits.
  BFT Gate Motor - Not working elyoussef.ali 1 6,376 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,143 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,391 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,206 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,699 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,370 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,885 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,001 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 3,108 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 17,228 11-04-2024, 08:08 AM
