  • 322 Vote(s) - 2.65 Average
Chamberlain Liftmaster gate problem CB1
I have 2 lyn300k's(230v) controlled by a CB1 control panel. They have been out of action for a while as one of the arms broke. I have now replaced the arm but when i try and set the running time (open-closed potentiometer) the running time does not change and the gates are running passed the point which i need them to go.
Could it be that i have wired the gates up wrong or has this potentiometer broken?
If it has broken and i better off doing a straight replacement or upgrading (if so to which control box - ideally i don't want to have to add any more cables as i'll have to dig up my drive)!!
Thanks for your help.
(28-03-2012, 07:53 AM)tentotwo Wrote: Hi,
Firstly the Liftmaster SCS300 230volt system requires stops when gate is open and closed.So if the gate is travelling past the possition you want this means no stops and this will cause damage to the system.
This will have caused the motors to fail and may have damaged the circuit board. We can still supply replacement CB1 circuit board @ £135+vat and delivery
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 353 Yesterday, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 27,115 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Sun affecting gate opener ForestRon 2 11,983 02-09-2024, 03:54 PM
Last Post: ForestRon
  Liftmaster LA400 Defender 6 22,326 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 21,494 13-04-2022, 10:20 AM
  Problem with delay time CB11 milan 2 14,968 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 19,396 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 23,492 22-02-2021, 08:48 PM
Last Post: russ
  Loose gate stop but what wrench to use? bomitie 2 13,846 02-04-2020, 12:06 PM
  Liftmaster CB1 gates started to open themselves telnet123 4 35,423 01-01-2020, 09:43 AM
Last Post: pronosoft
