  • 364 Vote(s) - 2.8 Average
BFT opening problem
Hi. Wandering if anyone could help please. My gates are controlled by BFT Aries P control panel which was replaced last year, unfortunately the engineer has moved out of the area and am unable to contact. For some reason the gates will close when remote operated but not open, I have to unlock using the key and open manually. When I lock them and activate the remote the gates will close!!! could anyone point me in the write direction please. Many thanks in anticipation. Steve
This is probably due to the open photocells being obstructed, or a loose wire on the open cells on your control panel.
Guest Wrote:Hi. Wandering if anyone could help please. My gates are controlled by BFT Aries P control panel which was replaced last year, unfortunately the engineer has moved out of the area and am unable to contact. For some reason the gates will close when remote operated but not open, I have to unlock using the key and open manually. When I lock them and activate the remote the gates will close!!! could anyone point me in the write direction please. Many thanks in anticipation. Steve
appreciate it, Ill have a look, many thanks. Steve
Doesnt appear to be anything obstructing photocell and wiring appears secure. There is plenty of clicking from panel when closing but only one click when activating to open.
Further to the above, anyone know of an honest bft engineer in the Sheffield , Rotherham areas I could contact to arrange a visit. Many thanks. Steve
Hi, have you got the solution for this problem?
I have exactly the same problem with BFT RIGEL panel!!
can you give me some hints?
thanks, Leo
PROBLEM SOLVED!!!
was the bottom right relay, i bought a new one ( 12V DC, M type 2 poles, 10A monostable) and replace it.
now is working perfect!!!
Hi help enquired please. I have a Rigel 5 controller, when i press ped / leaf 1 button on remotes etc, both leafs open. Is this likely to be a panel fault or a wiring fault. Any suggestions welcome. thank you
(27-07-2023, 10:02 AM)Michael22 Wrote: Hi help enquired please. I have a Rigel 5 controller, when i press ped / leaf 1 button on remotes etc, both leafs open. Is this likely to be a panel fault or a wiring fault. Any suggestions welcome. thank you
Thanks for the message.
This may be down to the incorrect logic settings applied to the appliance connected to the control board. when the button is pressed what is shown on the display, is it Ped or Start?
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,144 14-06-2024, 12:12 PM
  Bft gate problem djkokalis 1 5,302 14-02-2024, 12:39 PM
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,286 09-01-2023, 10:29 AM
  PHOBOS N Manual Overide Problem Dazrob 3 7,079 06-12-2022, 07:29 PM
Last Post: Dazrob
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 19,900 19-08-2022, 09:30 AM
  bft hydraulic gate problem richh 4 27,683 23-12-2019, 04:36 PM
  Strange opening problem Baz1981 4 88,282 15-07-2019, 08:39 AM
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 63,170 23-04-2019, 10:11 AM
  BFT Rigel 4 receiver signal problem drmrking 1 12,807 10-09-2018, 05:34 PM
Last Post: drmrking
  BFT A 40 not opening tojo 0 7,519 06-12-2017, 11:29 PM
Last Post: tojo
