  • 12 Vote(s) - 2.92 Average
CAME BX-B Clicking
Hi, I hope someone could give me some advice on what the problem could be with my gate.
It has been working fine since I bought the property 3 years ago, but now the gate won't respond, when I press the remote I can hear a clicking noise, but there is no movement.
Anything obvious to check what could be causing this?
[Image: GetAttachmentThumbnail?id=AQMkADAwATZiZm...ation=true]
(20-09-2023, 05:32 PM)marktinworth Wrote: [Image: GetAttachmentThumbnail?id=AQMkADAwATZiZm...ation=true]
Hi Mark,
Thanks for the message.
is there any chance you can provide a video of what is occurring? there may be a fault diagnosis on the display there.
I'm finally trying to get this sorted out, I'm fed up with having to push the gate open everyday.
I've just replaced the transformer as it was very corroded and overheating.
This hasn't solved my problem and the gate is still stationary.
When I press the remote, all I get is a click which seems to be coming from what I presume is the motor on the right side, apart from the click, nothing, not even the amber light flashing.
Does this mean the motor is dead and needs replacing, or is there a repair solution?
Many thanks for any advice before I end up replacing the whole unit.
