  • 24 Vote(s) - 2.92 Average
Set remote to “only open” gate
On Rigel 6 a button press on our remotes will:
Pressed whilst closed -> open
Pressed during opening -> stop
Pressed whilst stopped -> close or open (depending on what they were doing before they were stopped)
However we would like to change it so that a button press will only ever open the gates. This avoids the annoying occurrence where one person has clicked to open and another unknowingly presses on their remote and stops the gates. Gate will close automatically after usual delay.
Is it possible to change the settings?
(17-01-2023, 08:36 AM)mark123499 Wrote: On Rigel 6 a button press on our remotes will:
This will be done in the parameters. You will need to go into the "logic" section and change "1ch" from "0" to "2". What this is doing is changing the logic of the remote from step by step to open only.
Hi Sam,
Thank you for getting back to me on this. I've found the settings on the board but have not yet made the change.
Am I correct in thinking that the change you have proposed would mean that a button press would open the gates and they would remain open? I would like them to close after a time delay. But would also like it set such that a button press will only ever open the gates.
Really appreciate your input, thanks again.
Mark
(23-05-2023, 08:46 AM)mark123499 Wrote: Hi Sam,
Mark
I also want to know this thing about the gates.
Yes the work is must appriciatable.
Sam’s method worked. Setting it to “open” still means the gates close after the Tca (automatic closing time).
All is covered on the manual. Extracts attached. I’ve scribbled out the password section as we don’t have one set (which is the default setting)
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 2,158 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,428 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,231 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,574 03-02-2025, 11:29 AM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,393 15-10-2024, 10:37 AM
Last Post: Sootylfc
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,054 14-06-2024, 12:12 PM
  Two BFT pairs of electric gates (one remote) Harry44 1 4,543 04-06-2024, 01:30 PM
